three_jeeps
I am planning to retrofit the ½” copper water lines in my house basement (typical mid 60s suburban home) from the entrance line after the water meter (in the basement) and all the various runs in my basement joists to the hot water tank, stationary tubs, to the vertical risers that supply first floor kitchen sink and second floor bathroom. At this point, I am only going to change the piping in the basement and attack the PEX to the vertical risers. I’ll deal with the in-wall piping at a different time.
I am a fairly competent DIYer and I have some basic questions about doing this retrofit with PEX.
I plan on directly replacing the copper pipe 1 to 1. (I may consider upsizing the diameter from ½” to ¾ o 1” to help with volume delivery.) There are no pressure issues currently.
1. I am interested in using the most common PEX pipe and tooling. In my reading so far, I think PEX-A is the most appropriate over the others. True?
2. Type of fitting is most common/ best? (The most common may not be the best, I’d like to know)
Choices I think are most appropriate:
a) Crimp: PEX Crimp tool and copper crimp rings
b) Clamp: Clamp (Cinch) Tool and Stainless Steel Cinch Clamps
c) Expansion fitting: Uponor (Wirsbo) proPEX
Some of the areas are potentially a tight fit, so an angled tool head or 'mini tool' might be required as well as a straight inline tool - suggestion?
3. Good online supply houses? (pexuniverse?)
I am not concerned about tooling costs or component costs – I’d rather use the right stuff rather than use the ‘cheap stuff’ I’d like Comments/suggestions/guidance from the people who do this for a living and/or have some experience.
Thanks for any help...
J
J
