Hello to all.
I replaced the tank diaphragm and added air at 38.6 psi. After 20 minutes, it dropped to 37.2 psi. I tested schrader valve and around it with soap foam but found no bubbles. I also tested around the flange no bubbles. How could air leak?
(Note the tank is not yet installed in system)
Thank you for your time.
