Seeing how this was the third time I had to do this, I didn't think that would be an issue. The first two times I didn't re-install the trim until I saw there wasn't any leaks.Never install trim before water is turned on, you need to check and make sure no leaks inside the wall before installing trim
I can try that, however I am woundering if there is something else wrong somewhere else, as there is a small ammount of water comming through that faucet when the main is shut off.Call Moen and tell them that your shower posi temp faucet is bad and was wondering if there is anything
they can do. Tell them you already tried to new cartridges. It might not hurt to try. They have been noted
to replace the whole faucet and you sound knowledgeable enough to replace this yourself.
Out of curiosity, why was it fine before the original cartridge swap?That water coming out of the faucet when the cartridge is out has nothing to do with your drip. It sounds
like you have a bad faucet body.
You need to start your own thread.I have the exact same problem just with a Delta. I solved it the same way. What causes this to happen? Is the limiter going to be a temporary solution? Should I get another cartridge?
