Tovermier56
I had a leak from the right side facing the toilet between the tank and bowl. Bout a universal repair kit for Ferber 98 model toilet. Replaced flush valve and refill valve. Results in large amounts of water gushing from original small leak area.
Gasket is good
No leaking from replaced bolts
Gushes water only when flushed
Bolted down evenly confirmed with s level
Tank is tight cannot shift or wiggle in any direction
Lock nut on flush valve double checked for proper seating and tightness
No visible or felt cracks in the tank or bowl
Why do I have a worse problem than I started with
Gasket is good
