Mitchell-DIY-Guy
We here in NC follow state mandated rules, a detailed Standard of Practice or SOP for each inspection. Not every state has such rules nor are they the same. Some states don’t license home inspection.
Like plumbing or electrical codes, which such licensed contractors are supposed to follow, there’s a reason why each item is mandated or not, and not everyone agrees with every item.
Regarding the T&P valve, it is likely the valve works regardless of whether it’s tested or not. If you do test it, the possibility exists that it may not fully close after testing thus creating a leaky situation that must be addressed. If the inspector tests it and it leaks, usually the inspector will be responsible for its repair or replacement. This is a situation nobody likes…”But it was not leaking before you tested it!”
We’re responsible in NC for testing “normal operator controls”. The T&P valve is not a normal operator control. It is an automatic safety control.
More specifically, in NC, …The home inspector is not required to…Operate automatic safety controls…Operate any valve except water closet flush valves, fixture faucets, and hose faucets…
Like it or not testing T&P valves in a home inspection will generally lead to trouble for the inspector. If I see problems with the water heater (and I see plenty of those) or evidence of past problems (staining from prior leaks) I detail and photograph the issue(s) and the inspection report will indicate “further evaluation by a qualified contractor is suggested”.
Likewise, the test button on a smoke detector isn’t a normal operator control. If the homeowner is present and we can be assured that the smokes are not connected to any other alarm or reporting system they’ll be checked. In a majority of homes I’ve inspected the smokes are older than 10 years…in that case they are beyond their rated life and the report will indicate that.
My preference is not to pay for repairs or replacement of items in someone else’s home.
