Virwill7
Hi folks. The pump noted above has begun intermittently failing to pump out water (mostly from the basement laundry), forcing water out from under the lid and making a real mess. A few forceful plunges from a toilet plunger usually gets it going, but I'm getting tired of babysitting it. I'm no plumber - just a homeowner with a try-to-fix-it mentality. I got it unhooked (it was installed by a plumber) and removed the top w/the pump attached on the inside. Cleaned it out and worked the float a bunch, thinking that maybe it was seizing. (The pump does its job when it works so other than turning on and off, it's gotta be the float, right?) Reassembled it. At first, not bad - it would fail only once every 10-15 loads. Today, I was having a real hard time getting it to work. It's 9 years old and I could drop $300 on a new pump, but I hate the idea of tossing a perfectly good machine away when there might be a simple fix by disassembling the pump itself. Of course, I have no idea what I'm doing, and the company isn't much help. All of this is a long way of asking: Is this a familiar problem a guy like me could get to - say, a dab of grease on the inside? Is this worth getting professionally repaired (if I could find someone to do so)? Or, if you were me, would you just drop the 300 bucks on new one? Many thanks.
