I need to remove this faucet, but I don't see any mounting screws nuts. It's almost looks like one solid/fused piece. Does anyone have any ideas? I would very much appreciate it!
Remove the pop up rod from the spout. Through that same hole use a medium size long Allen wrench to turn counterclockwise.
I’m not sure of the exact size of the Allen wrench to use.
Of course you’ll need to unscrew the lower half of the handle counterclockwise. After those are removed you’ll see a C-clip on the hot and the cold. Remove those c-clips with a flat screwdriver.
Once all that’s done the faucet body will drop out of the bottom of the lavatory.
That’s a Moen Mini widespread. The model is Monticello.
