It's a whirlpool electric whirlpool. See pic above. ThanksI assume you are talking about a water heater dip tube. What brand is it? What model? Pictures?
I'm changing it because my HW runs out real fast. Cant fill a standard tub anymore. I assume the DT is cracked as its about 9 years old. Heating elements seem test good and HW is hot for a little bit.I meant a picture of the nipple. I assume you are changing out the dip tube because it is broken. Those nipples are often hard to remove. What size pipe wrench are you using? The tank should be full of water, and you need either a larger pipe wrench, or a cheater (a piece of pipe) on your pipe wrench.
Thanks. good idea."They" also suggest inserting a 5/8" carriage bolt into the nipple to avoid it collapsing. ( Same as removing anode when it's part of the hot water outlet )
http://waterheatertimer.org/Replace-anode-rod.html
