Hi,
I have a heat pump normally conceived to produce Domestic Hot Water, but I want to use it to feed a water underfloor heating system. The heat pump is equipped with the normal hot and cold in/outlets but also a recirculation outlet. I'm wondering which one I should use in the present case as I don't understand what the difference is between option A and B (see schematics). Anybody has an idea? Thank you.
