choc-holic
Hey all,
Just wondering if anyone can help me out with this conundrum of mine.
I'm currently renting a unit in an apartment and I live on the highest floor (3rd floor). This is my second winter staying in it and once winter comes (as with last year) the hot water supply becomes unpredictable. Whenever it rains throughout the day or when the weather is really cold, the water heater tank somehow doesn't heat up the water. Only cold water flows out, sometimes luke warm. A lot of the time this continues for two consecutive days before hot water flow resumes.
During summer the hot water supply is fine. There may be the occasional one odd day where the hot water supply is cut but that doesn't bother me.
The agent has sent plumbers and electricians, all of which can't seem to find or think of any problem with it. The plumber has even changed the water heater tank (each unit in the apartment has its own tank). But the problem remained.
The water pressure in the unit I'm staying at is low (according to the plumber it's because the unit is on the highest floor). And no one else in the apartment seems to have the same problem. No long showers are taken, I don't even use hot water to wash the dishes or laundry (for fear that the hot water supply may 'run out').
Hopefully someone in this forum is able to suggest some possible solutions or may have an idea of what the problem may be. I would be eternally grateful. The only reason why I bear with this apartment is the trouble of moving out and its location.
Thank you in advance.
