Radiators - easy to change?
WOOOOOOOOOOO up their Cowboy!!!! if that is a hydronic rad. when you unscrew it.
You will unleash some of the foulest smelling stagnet water,you ever smelled.
it will come out of that pipe and will not stop till the system is shut down, the rust and oil in the water will stain the carpet and wood floors not to mention the 3rd degree burn you will receive,
none of that will compare to the whoop'n your wife will put on you for causing such a mess.
I n my opinion, with it and a 5 dollar bill,you MIGHT be able to afford a foo foo coffee at starebucks
but, I would find the boiler, shut it down, let it cool, drain the system of pressure, then unscrew them pipes
