Helgi_Hundingsbane
We are replacing our Well Pressure tank. My concern is about losing prime, because there is no cut off between the pressure tank and well. I have posted pictures below of the Pump we have. I have included Photos below. When i add the new pressure tank, i plan on added a cut off between the two. I don't want to accidentally drain the pump chamber..
What is this thing im pointing to on the pump? is this where i prime the pump, if needed? And what is else is it for?
What is this port for?
Here is more info about the pump:
- In the 1st pic what is this thing im pointing to? The PVC goes to the pressure tank.
- in the Second pic is this the plug on the well head?
- Can replacing the pressure tank cause the pump to lose prime?
- Any other advice or tips are appreciated.
