Hey all:
New to this forum. I am in the middle of construction in my house. I asked the contractor to re-build the water tree that enters into my house through the basement. I had a bad pressure regulating valve giving me 100 psi through the house. So I had him replace that as well as add a Moen leak detector and give me some stand offs for a future water softener that I am going to install.
I wanted bypass for both the water softener and the Moen leak detector. For this I asked for 3 way T port valves.
The plumbing contractor ended up buying these:
https://www.amazon.com/gp/product/B09719YL4X/ref=ask_ql_qh_dp_hza?th=1
I expected a more expensive Brass 3 way T port valve but this is what he went for. He says it is safe for potable water since it is stainless steel 304 but I don't see any mention of "potable" on the link. It says it is ok for use with water but doesn't specify "potable".
Should I be concerned about these valves or are all stainless steel ball valves that are rated for "water" can also be accepted as safe for "potable water" as well?
Thanks all!
Thanks all!
