riverboatdon
So I have a 2 pipe well pump that pumps water from my 60ft well, there’s 38 ft of water in there and 55ft of pipe. Recently I had a bunch of mud stir up in the bottom and get sucked into my pump. So I replaced my foot valve and a whole new water filter housing and filter. The water runs out of the pump at 20psi. The pump ran continuously and wouldn’t cut off once I replaced those things. So I changed the points (pressure switch) with new 20/40 points. Made sure the clear tube that comes off the side of the pump housing and runs to the nipple on the points is clean and clear, and again it wouldn’t click off. So I started suspecting the diaphragm was bad considering my pressure gauge wouldn’t read above 0 psi. So I replaced it with a brand new 20 gallon diaphragm tank, new T to the tank, and I have good water coming out of them. But still I cannot get it to go above 20psi so the pump runs continuously. The air pressure in the tank is 18 psi or within a psi or 2 of that on the high side. I have a shutoff valve right on the other side of the filter so no water is running to the house just within 5 foot of the pump and diaphragm tank. So my question is what could be causing it to not build the 40 psi to cut off? My guesses are 1 the pump when it sucked up the mud and sand it damaged the teeth on the compressor and cannot produce enough pressure to fill up the tank and cut off the points. Or the pipe that runs down into the well into the water has a hole in it. Anyone else have any suggestions on what it could be besides those things?
