Aloha all, we had a full house last week and now were having trouble with water pressure. My 1/2 HP Grundfos well pump has recently started taking an exceptionally long time to pressurize my tank (15-20mins). Cut in pressure is 30 PSI cut out pressure is 50 PSI. We have a 44 gallon Fexcon pressure tank. While pumping the pressure gauge needle is jumpy and before the problems started our faucets were spitting when first turned on. I've checked our catchment tank for blockage and there is none. I've also cut water to the house while pump was running so I know there is no leak on that side. My first suspicion was that water levels were too low in the tank and our pump was sucking air. Could air be stuck somewhere and be creating this problem? Or does this sound like a pressure tank issue? I drained and checked the pressure tank and when doing so I was unable to reach 0 PSI with open faucets and pump off. When water had stopped coming from the faucet my gauge still showed 10 PSI. Plumbing is not my trade so please bear with me. Any info or advice is greatly appreciated.
