Hi, I have a 1hp 230V underground pump that will not turn on. It was working fine when I bought the house, but I forgot to have the electric switched over to my name, so the power company turned the power off and I have not been able to get it to work since the electric was turned back on. I've tried switching the breaker switch off and on, cleaning the pressure switch contacts of any carbon build up or debris, replacing the control box which included the capacitor and relay, and searched for burned wires.
Also, something worth mentioning is that there is no voltage going through the wires directly from the box or the pressure switch any time I switch on the breaker switch for the well. It's either very little to none.
I do not know how old the pump is. The tank is only 6yrs old.
I would appreciate any and all advice as to what the issue could be.
Thanks,
Joe
Note: the control box pictured is the old one
Thanks,
Joe
