Septicissue
I know nothing about well pumps but here goes.If I use a lot of water (like washing the car) my pump stays on but pressure only builds to around 20psi without shutting off or reaching 30psi.I am still getting water just at low pressure.If I turn power off to the pump and let it stay off a couple minuettes and then turn the power to the pump back on then the tank fills and shuts off at 30psi which is where it set to shut off.I can also hear burps of air going into the tank when I turn it back on.
A neighbor and I awhile back replaced the cut of switch (guess that's what its called and I just replaced the pressure gauge.
My pump is a below ground pump.I have read of priming the pump but do not know how.I have read of check valve but not sure what that is either. Any help would be greatly appreciated.Also and not sure it means anything but when I take a shower there is air coming from the hot water .This all started during the summer when I was away and water hose running and it ran for about 12 hours.Thanks for any and all help.
