doitmyselfdean
Well .. turns out my plumber didn't adjust the PRV from the factory settings of 45PSI. thats why I didn't have the immediate problem again. I checked my pressure and set it back to 60 and I have all the same problems. So..2nd PRV same problem.. I guess its not the PRV. I could cry lol!! So trouble shooters: This is what I have done to try to pinpoint the problem and location.
While the sound is occuring-
Closing the Ball Valve shutoff on Backflow Febco65(outside near hosebib and sprinkler manifold box)= no effect
Turning Gate Valve Below PRV = No Effect.
Closing the Ball Valve shutoff on irrigation-T in basement = stops the sound (only if the sound is happening when the sprinklers are running)
Closing the Ball Valve shut off on the cold water to waterheater changes the sound of the chattering, but doesn't stop it. (no thermal expansion tank installed) ; this is 30-40 ft away.. any explanation?
All Toilets are QuickFill/Not BallCock / All Anglestops have been replaced.
Also FYI this intense hammering doesn't immediately start on the sprinklers (this house i bought has 8 zones..yes 8 don't know why they installed it that way. The timer is programmed to run 2x in the am per zone. It can run through all 8 zones fine the first cycle, then... zone#6 kicks in on the 2nd cycle and BAM... the hammering starts.
This is not only a sprinkler issue; as it happens when the sprinklers are off and I flush any of my quick fill toilets and they are in the "filling mode"
Thanks for your help...
