I recently purchased a house and the inspectors said I needed to install a Pressure Reducing Valve as the pressure measure at the spigot outside was 80 psi. I've measured it at 78-80 pretty consistently since we moved in.
So, I have a few questions:
-Is 80 psi high enough to necessitate installing a PRV?
-If I install a PRV, do I then need to install a thermal expansion tank on my water heater or are the two not always necessary together?
Thanks a lot for the help!
