superdave17
I have a basement that has 4 washers and 4 dryers. I'm looking to space each washer out around the basement so they are not all crowded around the utility sink. This means running water lines, drain lines, and electric lines to each locations. The water lines and electric drops are no problem. However, I have heard different suggestions on how to run the drain lines.
See the attached pictures.
I'd like a washer/dryer set where the garbage cans are. A washer/dryer set to the right of the garbage cans around the corner. A washer/dryer set under both windows (where the washer/dryers are now).
I was given the following suggestion:
Run 2" PVC drain in each location with an AAV and P-Trap into a 3" main that runs into the cast iron stack.
Does this sound like the best approach to this project? Is pitching around and in between corners an issue? Do you have any other suggestions or recommendations?
