AJay
Moron
Have finally gotten back to work on the bathroom project and am about ready to finish gluing and screwing down sub0floor as well as starting to put up some of the backer-board for the shower.
Up to this point, I have only been testing the copper supply tubes with air from my compressor and am confident that there are no leaks.
However, I haven't actually put water into the system, part of which isn't complete as I don't know exactly how the piping for the tub will go. This is because I will likely have to modify the tub frame.
Two thirds of the sub-floor is already down so if there is a leak I'm in big trouble.
But there were no leaks with the air, which I confirmed with soapy water sprayed over all the soldered joints.
Part of me is telling me to test with water what I have installed (using Shark-bite ends caps on the unfinished stuff) while another part is telling me that if it holds air it will hold water.
