Hello,
I have recently encountered a problem with my well that has me a bit confused. I have a submersible well pump that I've never dug up so I do not know the brand. A couple of months ago my well pressure tank bursted, so I changed it with a flotec pressurized tank, all has worked well since then.
Well, recently I have noticed a drop in water pressure, not huge but noticeable. When I turn off the breaker to the well and drain the tank via the kitchen sink, not much water comes out, maybe 3 gallons until its dry. I believe the flotec unit is 18 gallons and it is also piggybacked to another older tank. After I turn the breaker back on, the pump never noticeably kicks on. it doesn't make any noise as far as motors running but you can hear the water filling the tank and the gauge builds to 40psi. The pressure switch is a square D unit if that helps, with no apparent low pressure kickout switch.
I am wondering if this leans more towards the pressure switch or the well pump? I have working water, which I would think I would not if the well pump went bad. I cleaned the wiring to the pressure switch and still nothing. Thanks in advance for any help you can offer.
Armond
Armond
