My bandwidth will not be unthrottled until the 12th but I got one pic on this page to load. How do they support that pressure tank so it stays horizontal like that?
For the float switch-- Could I take maybe some PVC pipe (if it is small enough) to fit in to the hole that the rod goes through & put it down in the cistern so a float or solenoid valve can attach to it & run any wires up inside that PVC pipe to connect to something to turn the pump on and off?
I keep seeing sketches of such setups but no actual photos (since loading is an issue) and am not sure how to set that up. I know solenoid uses wiring but I'm not entirely sure how it all works or how to hook it up. I will have to measure the hole the rod goes through.
I also still intend to raise the pump up. One of the bends is leaking now bc it needs to be tightened more. Problem is, there is no longer a shutoff before the pump. I need to figure out if it's possible to add one. Could one be added just before or after the check valve? I think I have the shutoff to install but not sure if there's enough room on the pipe. Although, if I raise the pump up more, I might get a little more room for piping. But again, I will have to shut off my pumps and let the tank drain completely before I can cut any of the pipes coming out. Still a bit miffed that the guy didn't install a shutoff when I specifically said I needed one.
