needprotection
Unfortunately I do not know much about plumbing and appreciate any guidance I can get. These pipes are about 9 years old and this is in the hot water closet above the hot water heater.
The pipes come out of the wall, down, into this black thing, then back down and back into the wall:
The water is a slow, steady drip. The water is seeping out where the brass/copper screw goes into the black thing. I checked the meter in the front yard and it's not moving at all. It seems like a washer or a seal inside this black thing (what's it called?) malfunctioned or something and is allowing the water to seep out.
The water is warm and the drip is very steady and consistent.
I guess my question is: Is this something I can fix and since this is hot water - I assume the water is shut off valve is somehwere around the hot water heater or around this pipe?
The pipe has me confused because it comes out of the wall and back into it - it doesn't interact with the hot water heater in any way inside the hot water heater closet.
Thanks in advance for any advice
