gregol1962
I recently had a professional plumbing service install a one piece pressure balancing tap system to replace an outdated two tap system. They assured me it would prevent getting scalded or frozen in the shower. It does not work at all. You can get the water temp set, pull up the button on the tap and the shower is fine. A few minutes into the shower the water goes scalding hot. So, you press down the button and out of the tap is coming the correct mix of water temp. Pull the lever up and again you get scalded. The company that installed the taps tells me that happens occasionally and that I am expecting too much or that someone fushed a toilet, ran a tap, etc. Correct me if I am wrong, but isn;t that the whole idea of a pressure balancing system??? I got no where with them and they refuse to come out to address the problem, telling me there isn't one. I am an intelligent, well-educated person and I do not appreciate them patronizing me. Any suggestions before I call yet another plumber to come out and try to fix it, and pay even more money? Any suggestions would be appreciated.
