Brad L
- Joined
- Jun 6, 2023
- Messages
- 7
- Reaction score
- 0
Hi there, I am not a plumber myself (as I'm sure will be obvious by the naivety of my questions in this post). I had a plumber here a week ago and he replaced pipes under both my bathroom sinks and also replaced the taps on one sink (following from leaks). I assume all he would have used was PVC glue, and from what I've read about it, that should dissipate in hours, but in the one bathroom (where he replaced the pipes and also taps), the smell is still so strong that it burns my nose contantly 7 days later. And, oddly, it is by far the strongest when I turn on the tap. I'm not sure if it's the water itself, or if it's wafting up through the drain, but in either case it doesn't make sense to me because I can't think how the glue would be inside the pipe and even if it was, why would it still be curing and giving off a strong smell a week later.
Also puzzled why it's occuring in that bathroom (where the pipe and taps were replaced) but really hardly at all in the other bathroom where it was just the pipes. That makes me wonder if it's something to do with the taps replacement rather than the pipes. Either that or is it possible he made a mistake and applied so much in this case that it's not curing, or some got inside the pipe and since it's wet in there, it's not drying and just continuing to waft up through the drain and for some reason running water through does nothing to stop it? I'm hesitant to ask him to come back for that, and not sure the smell would even be noticeable to him as I would guess he works with this daily, but to me it's really an intolerable smell.
So, I'm trying to figure out a) why it's occurring, b) if it's any concern (beyond annoyance) to be inhaling these fumes which really should be inert by 1 week after the work was done (!), but still smell very noxious, and c) how to stop it from continuing to smell. I've tried running the bathroom exhaust for many hours, but it's made no difference. I've tried running water down the sink (for as long as I can stand the smell) but that hasn't seemed to reduce it either. Don't really want to just mask it with a different scent, because then I wouldn't know if it's still occurring. Just want to figure out how to get rid of it altogether. Thanks in advance for any advice!!
