Phillyk610
Hey guys! I found this forum searching for answers to my question. I can’t find anything so hopefully someone here can help me. I am not a plumber but used to do a lot of outside work running rigid and pvc pipe when I was in the electrical union and do most of the work at my house.
I just got a pool heater basically free and would like to get it hooked up asap. It is a natural gas heater and I bought the propane orifice to convert it.
Long story short, my neighborhood just got natural gas lines installed. To run a line to my house they said it would cost $2100. I can’t afford that right now but plan on doing it in the next year or two. I currently have a 120 gallon propane tank that just feeds my fireplace insert. I know this is far below the size I should have to run a pool heater. It is only a temporary solution until I get gas ran to the house and will only use it on colder days.
My pool heater (400k btu) is around 125ft to the propane tank and the gas meter will eventually be in that same area. From my understanding I would need a 1 1/2” pipe to run natural gas. I know propane doesn’t have to run through as wide a pipe. Pentairs website says 1 1/4 for propane, which still seems big but whatever.
My question is: can I run propane through the 1 1/2 pipe temporarily without issues until I get natural gas hooked up? I know another solution is to run a separate pipe for each but am hoping to avoid this.
Once I run the pipe I plan on having a buddy help me with the final hookups and pressure testing.
Thanks for your help everyone!
- Phil
- Phil
