Adding some more information to my diagram: The pump sits within a covered sump that the pond drains into (this is an oversimplification - the plumbing in there is somewhat protected). There is a very short run that is exposed before plunging into the ground. This is followed by a 28 foot run buried below the frost line. The flow then rises vertically and is discharged at the head of the stream feeding the pond (the stream head is supported by two retaining walls - not shown). An electrical conduit runs parallel with the buried plumbing.
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .* *discharge
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .* . about 30"
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . * above grade
. . . . 24" run max . . . . . . . . . . . . . . . . . . . . . . . . . . . . . * . . . . . . . . .
=| . .* . |= *====== finished grade =================*============
. |---*--| . * . . ---water level--- about 6" below grade . . * . . . . . . . . . .
. | pump | . * . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .* . . . . . . . . . .
. +------+. * . . frost line - about 30" below grade . . . . . . * . . . . . . . . . .
. . sump . . * . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . * . . . . . . . . . .
. . . . . . . . . . . . 28' run @ 36" below grade . . . . . . . . . . . . . . . . . . . . . .
A heater can be placed within the sump providing several hours protection without power for the plumbing contained there. At risk is the short run before entering the ground, the vertical sections entering and leaving the ground, and the exposed section just before the discharge.
I see what you are saying, that if all horizontal sections have a gentle slope back to the pump with no place for water to pool, then the pipe would drain itself in the absence of any check valve. That solution (actually the one most frequently used [with nearly straight streams]) has its problems too. A much longer run would be required to avoid stream crossings (my stream will not be straight), digging to move ornamental plants and trees is frequent in this area, and I would have to go through the base of two retaining walls.
The size of pump required depends on the size and number of fish and other animals living in the pond, the filtration system, water temperature and many other factors. The flow must be sufficient to allow the good bacteria to convert all biological waste into harmless chemicals. For my size pond a 1000 gallons per hour pump would be sufficient except for extreme fish loads. I may be able to get by with much less.
I have two pumps. The G210 for 24/7 use and the G535 for extra effects or continuous use if the smaller pump is insufficient.
The G210 has a maximum lift of 7.4 ft. and will deliver 210 gph @ 1', 170 gph @ 2', 119 gph @ 4' and 61 gph @ 6'.
The G535 has a maximum lift of 12 ft. and will deliver 535 gph @ 1', 502 gph @ 2', 434 gph @ 4' , 356 gph @ 6', 282 gph @ 8' and 175 gph @ 10'.
Bigger pumps generally have greater lift and cost more to operate. Pumps must run continuously in warm weather to prevent growth of septic bacteria.
Wirsbo can thaw and freeze as much as you want but the brass or plastic fittings you use are a different story. I suppose if you had no fittings underground where it cant be drained would be the solution if thats possible. Ive never tried that so im not too sure but i would imagine low pressure like that it would hold up just fine. Definitely not installed as its designed but I would test a small portion before doing the whole thing like that.
Not sure what you mean by the low pressure being a factor to hold up longer, and what are you suggesting that I test?
