Attempts Plumbing
Hello!
I recently bought an older home and while the home inspector said there was a "flow issue to the shower" I don't think he fully captured the level of "the issue" which is down right terrible... After taking a look in the basement I see that that 90% of the pipe is galvanized and very rusted at least on the outside and uselessly complex, hacked and slashed together with random pipes capped and lots of elbows throughout system which looks like it's been "customized" over the last 50 years of the home's 100 year life.
This being the case and doing a bit of reading I've decided to replace it all with pex for a handful of reasons. Cost, DIY'ability, ease of install, and future upgrade potential. Not knowing much about plumbing I have a few questions about Pex, line size, pressure, and best practices.
The house has all of it's water fixtures on the north and south side. I am thinking about running a dual manifold system, north and south, and break out to each node with 1/2 pex-b. The main comes in the north side and the hot water heater is on the south side of the home, I am planning on running cross connect (3/4 pex-b hot & cold) between the two manifolds and 1/2'' to each of the nodes or to easiest node connection point leaving the newer copper where it looks good.
Few questions I have:
Cheers,
Jason
- Does the size of my cross connect matter?
- I wanted to use pex-a at 1" in hopes that the extra flow capacity and flex would give me more of a buffer or capacitor effect to stop pressure drop off and/or shower cold spots, but opted against it in this iteration for water savings vs comfort. Logical?
- It it worth while to branch off the manifold for each of my nodes in the kitchen and replace lines where there is a "T" ie, the sink hot line to the dishwasher, and "T" from the washer to dryer?
- To keep everything uniform i would love to have a line from the manifold to each node but cost vs performance is where i am under educated.
- Is the overall design viable from a plumbers / code / usability perspective.
- I am not a plumber and a spot check would ease my mind and help plan final equipment purchases.
- Would it make more sense to "single flow" the whole system?
- instead of "T"ing the cold out in the bathroom and closing that run, to move the cold cross connect to the end of that run then go to the hot water heater? In this model main in would be a continuous run from main to the bathroom hot line closure.
Cheers,
Jason
