kiwi_outdoors
Technically - correct, and thanks for adding that item.It should be plugged in or disconnect from the access point. That’s a violation I wouldn’t let slide.
In practice - its owner-operator till I die.
Its dedicated circuit #7 with a local disconnect switch in the kitchen - so that will have to do.
I will add a notice inisde the access door identifying the circuit breaker # and othe rrelevant info.
