Pipe support clamps for foam insulation
michig54
Apr 24, 2015
Hello all,
I plan on wrapping my pipes in my crawlspace with foam insulation that has 1/2 in. walls. The pipes are 3/4 in. and 1/2 in. in diameter. Currently the pipes are being supported to the floor joints using these pipe clamps:
Since these won't fit around the pipe once the insulation is installed, what can I use instead? I haven't found anything that is the appropriate size. I need something that would work with 1.5 in. and 1.75 in. Any recommandations? Thanks in advance!
Thanks! I imagine I'll find these in the electrical section. I'd also have to get some wood screws. Do you recommend an appropriate length?
I use 1-1/4" galv pipe straps for 1/2" and 3/4" pipe copper tube. it holds a bit tighter than the 1-1/2" clamps.
I just use drywall screws
when using insulation I also use wire pipe hanger.
