Pex Fittings - Plastic vs Brass
TCnCinti
Jan 9, 2016
Cincinnati, OH
I am installing some Pex tubing in the baseement of a house that has had the copper cut out while it sat vacant. Looking at both plastic and brass connectors. Is there a consensus about which is better? The plastic is certainly less expensive, but it seems as though the opening narrows considerably (down to about 1/4" it seems on the 1/2" connector). Will I notice an appreciable drop in pressure/volume if I use Plastic? I want good water pressure/volume so I have no problem spending more on the brass if it's better. Thanks
