Rhettccampbell
I am looking for some assistance with the my Pex plan for an upcoming remodel. I have included my sketch plan, based on research for the best system(s), however, there appears to be a fair amount of debate with regard to the best system/method to use. I am hoping someone would be willing to provide some input (even if I am on the wrong track completely). Currently, the plumbing is approximately 35 years old and is copper buried in the slab, which has led to a few leaks recently. The house is in Southwest Florida, so Pex can feasibly (and legally) be ran through the attic. While I have done plumbing projects over the years, I have never designed a system and I cannot afford an engineer to draw the plans up.
I have never been a fan of wasting water, therefore I wanted to stay away from the trunk and branch system, and instead I wanted to put a recirculation system that is either ran with a timer, or an Aquastat flow sensor.
This setup includes a mainline coming in from the left side of the house. I plan to loop the hot line with 3/4" loop with hot with reducing Tee's to 1/2" to each fixture, with the exception of the Master Bathroom Dual-Sink Vanity, where I’ll branch off the first connection. A spring-loaded check valve will e placed before re-entering the cold line and another spring-loaded check valve will be placed between the incoming water and the water heater.
The cold line would be a similar setup with regard to distribution to the fixtures. A separate line will run to the exterior hose bibs, with an in-line spring loaded check valve before the 1st branch. I plan to use the Wisbro Uponor Pex A, ProPex Expansion joint system with Brass Fittings.
My questions are:
My questions are:
- Where is best place to place the recirculating pump?
- Will this supply enough hot water to run multiple fixtures at once ( i.e. both showers while the dishwasher or washing machine are running)?
- Are my check valves locations in the correct locations? And do you still recommend vacuum breakers on each of the hose bibs?
- Lastly, since I will be removing a lot of the sheetrock in the areas where the hose bibs currently are (or will be) I plan to run the Pex down the interior side and then through the cylinder block wall. Frost proof is not necessarily needed (and seemingly an unnecessary expense). Do I run larger diameter pvc (or similar) through the wall, and then run PEX through the pipe and seal with caulking? Or is there a better alternative?
