Hey there,
I am a novice but have sweated many pipes, etc. I did simple plumbing on my outdoor shower and used ball valves with levers (not the garden hose dial kind). Anyway, one of them is leaking already only after a year or two. It leaks right out of where the nut holds the lever on. There is no adjustment or way to tighten it. It's the cold water one. In the freezing weather I turn off the water from the inside and drain the pipes well but I think this valve must have frozen or something. Here is my question. Are there valves made for outdoors that last longer? If I'm going to replace this thing I'm going to get the best.
Thanks for the help!
