Hello,
I failed to remove a hose from my outdoor faucet and the pipe inside the house broke. The faucet is a woodford model 17. I have access to the broken area inside and can see the split which is about 2-3 inches in from the outside wall. It looks like the pipe from the outside connects to the inside copper lines through a threaded connection but I can't get this to loosen. The faucet mounted on the outside of the house is mounted on brick and the holes where the screws would secure the faucet to the house are filled in with a brick mortar type mix. So, I don't know how to remove the faucet assembly or disconnect the pipe from the water line inside the house. Any help or suggestions would be appreciated. Thanks.
riley4
riley4
