I'm roughing on in my attic, and there are some situations where I can't figure out a way to get pipes where there need to go without violating the code for notching and boring in framing.
My current challenge is with the venting.
I have a first floor fixture group coming up into the attic via a 4" cast stack. I am running the new group, which is 2 stud bays away, with a 3" pvc stack. I want to reduce the 4" to 2", and tie it into the 3" above the flood plain of the highest fixture, connecting horizontally.
This means boring 2" holes through two studs in a partition wall.
My question is, Do people do this, then use stud shoes or something? Or do the plumbers just leave it for the carpenters to figure out later?
My other option would be to reduce the 4" to 3" or 2" pvc, then run straight up through the roof. That would mean compromising the top plate of the wall, which seems the lesser of two evils.
I would rather not have the add'l roof penetration if I don't need to.
I won't even get into my other framing issue, where I cut off the end of joists to get the toilets in. I am anticipating getting an engineer involved, and hoping I don't need an exposed beam below.
The third photo down on this page shows the 4" cast, 2 studs away from the stack I want to tie into horizontally.
The other pics show the cut joists, They used to bear on the top plate of the wall I'm running the drain inside of.
