Leaksealer
Hello,
The well line beneath my garage started leaking so I bypassed it by running new 1" black plastic pipe inside the garage. This required going up the wall across the garage and then down the wall to the crawl space.
Now I am only getting about 26 PSI of pressure on my line.
The amount of extra line that I am using is about 30', and it is going 10' up and then back down again, whereas before it was installed level under the ground with no rises on it. It is not that cold here so the pipes are not freezing.
Can someone please suggest a remedy?
Thank you,
JB
Thank you,
JB
