usetobefast
I am a plumbing contractor with 30+ years of experience but this new no lead brass is giving me the fits. I consider myself pretty accomplished with a torch but I just had a nasty leaker. I installed a Gerber 3 valve faucet on friday, and the customer called 24 hours later to say it was leaking. It certainly wasn't leaking when I left. When I got there the leak was not just a little dribbler but looked like a pressure washer. When I installed the faucet I soldered the 1/2"copper lines in the brass body upside down & had 2 very nice looking joints with good flow when I was applying the solder. After the massive clean up I took the joint apart & observed even & complete solder coverage on both the faucet body & the copper stub.I used Oatey solder with Utility flux ( zinc chloride) and a #5 turbo tip. Any help you can provide would be appreciated
