No hot water in only ONE faucet in the house
What will happen if you tie your hot water supply line into the dishwasher valve? If it gets good and hot, that hot water valve must be the culprit. If so, you can tee off the lower valve and run both your D/W and sink.
do you have a recirc pump at the water heater if so you could have a faulty check valve.
