BlackRiver
I have a submersible well on my property that was installed about 8 years ago before we bought the property. The former owner installed it to run an inground sprinkler system but never finished the system. It looks to be a 3 wire system. I believe it has a 6 inch casing and is a 4 inch pipe. I do not know the depth of the well, the HP of the pump, etc. but i am contacting the former owner to find these things out hopefully on Monday. As far as i know the well has never been hooked up to electricity or been ran. I want to hook it up and get it running to water my garden, and to pretty much use water from it outside instead of using my city water. The pipe comes out the top of the well cap, and has a pressure relief valve, then what i guess to be a ball valve. There is a breaker box about 8 feet away on my storm cellar. I will post pics when i get home as i am out of town at work. I'm slowly learning the things i will need to get it set up to run, and i will probably need lots of help and have many questions in the future.
But my first concern is: before i buy anything i want to make sure the submersible well even still will run. Is there a way i can hook it up and hear it run before i put out any $$$$ on it?
