Hi there.
I am planning on replacing our well pressure tank--currently we have a 22 gallon FlexLite FL7. Some numbers on our current setup are a 5.9 gallon drawdown volume and approximately a 2.2 gallon/minute well pump flow rate on a 1/2 hp pump and a 30/50 pressure switch. The pump runs for an avg of 2 min 40 seconds to fill the tank.
With 4 people in the house, the pump is frequently on for the duration when showering, doing dishes, watering the garden etc.
My questions are: does it make sense with these numbers to increase the size of the pressure tank?
If so, will increasing the pressure tank size do anything to our water pressure--either increase it or decrease it? Or does tank size only correlate to drawdown volume and how frequently the pump kicks on? (i.e. bigger tank=larger draw down, longer run time to fill, but fewer pump cycles on/off)
Thanks for the input.
