Rayayork
Hello, first time poster, long time reader looking for some help. I am installing a master bath in my new addition and have questions about flow and venting. There is a 40" crawlspace under the addition and the main sewer line out runs through this crawlspace. I have installed a 3" vertical vent from the crawlspace up through the roof of the addition to vent the bathroom fixtures. I am planning on a 3" sewer line under the bedroom to catch the shower, toilet and vanity. I plan on a 2" vertical vent for each location. The 2" vents will each rise from the crawlspace inside the 2x6 exterior wall and meet a horizontal 2" pipe via 2"x2" sanitary tee's approximately 4' from the floor. Each of the 4 drains will vent into the horizontal 2". The horizontal 2" will connect to a vertical 3" that rises through the roof with two 45degree bends before exiting the roof at 14" above the roof shingles. Will this pass inspection using IPC code in the state of Delaware? Any suggestions or alterations would be greatly appreciated. I have attached a hand drawing for a better visual. Thanks!
