Hello, I'm in the process of installing a new 40 gallon indirect water heater to replace the "on-demand" one in the oil furnace. The following is my set up:
I have an outdoor wood fired boiler providing all the hot water to the 3 zone baseboard system in my house. Heated water from outdoor boiler enters house, goes through the oil furnace (in the event I lose the fire in the outdoor boiler the oil furnace takes over seamlessly), travels through an expansion tank and then to manifold where it breaks down into 3 zones (a 4th zone was installed but capped off, not being used), water returns through another manifold where it goes through a circulator pump and then out to the outdoor furnace to be reheated and waiting to be used when needed. Presently the oil furnace is providing me with all the potable hot water. Because I use the outdoor boiler as my primary source to heat the house, I want to take advantage of the "free" heat the wood boiler is providing me, tis the reason for the indirect water heater. First question; Can I simply tie into the 4th unused zone at the tailend of the manifold to get the hot water to heater? Second question; Can I connect the zone valve to the aquastat on the water heater to allow hotwater to flow through the heat exchanger to heat my potable hotwater? Third question; Will I need a circulator pump? Fourth question; If yes, where do I install in it? Thanks for taking the time to read post and for the any answers you can provide me. Roger
