travish
travish
Messages1Reaction score0Points0Locationwashington stateI RECENTLY PURCHASED A 2 ACRE PARCEL IN NORTHERN WASHINGTON STATE. PRIOR TO BUYING I DID MY DUE DILIGENCE AND TESTED SEPTIC AND WATER...THE WELL IS A SHALLOW WELL THAT PRODUCES 4GPM WITH A 12FT STATIC LEVEL WITH 1 FT DRAWDOWN AFTER 1 HOUR.....IT HAS A BUNCH OF JIMMY RIGGED WIRING (EXTENSION CORD) A LEAKY CRAFTSMAN 3/4 HORSE JET PUMP (SMALL DRIPS occasionally) A 37 GALLON PRESSURE TANK AND THATS IT IM CURRENTLY HOOKED UP TO THE SOLE HOSE BIB WITH A GARDEN HOSE LIVING IN A TRAVEL TRAILER ON THE PROPERTY ......(THE WATER PRESSURE IN MY TAVEL TRAILER IS GOOD FOR SHOWERS BUT WHEN SINKS TURNED ON IT ROBS ALL THE PRESSURE...IM CLOSE TO FINISHED ON MY 2300 3 BEDROOM 3 BATH HOME AND JUST LAID THE 1 INCH POLY UNDER GROUND AND AM RUNNING A HEATER AND NEW POWER TO WELL HOUSE FOR PROPER SUPPLY. MY PLAN IS TO DIY A NEW PUMP PRESSURE TANK ( NEWER AND BIGGER IM THINKING) AND LOOKING INTO THESE WATERWORKS DIGITAL PRESSURE CONTROL SWITCH SO I CAN MIMIC CITY WATER OR ATLEAST HAVE GOOD PRESSURE.....IM ATTEMPTING NOT TO REBUILD ENTIRE PUMP HOUSE HOWEVER IF I HAVE TO I WILL.....WHAT DO I NEED STORAGE TANK? WILL BIGGER PRESSURE TANK AND NEW PUMP WORK I SEE A KINK IN THE HOSE OF TANK COULD THAT ATTRIBUTE TO IT WHATS THE BEST RECOMMENDATION ALL HELP APPRECIATED.....NEW BUILD HAS LOTS OF SHOWER IN MASTER NOT TO MENTOON I HAVE A HOUSEHOLD OF 6 NEW BUILD IS ABOUT 80 FEET AWAY FROM WELL
