cooch17
Last summer I had a brand new electric hot water tank installed -- a 50g State ProLine unit.
Ths past week-end,I did a tank flush, when I noticed something I wanted to ask about -- when I was draining the water out of the tank, no sediment at all (good!), but...for the first 5-6 minutes, the water coming out of the tank was only lukewarm at best -- definitely not hot. It eventually *after 6-7 minutes of draining (whole process took ~25 minutes) got hotter, and then fully hot. I know that in the tank the warmest water is at the top (so it would make sense that by the time that part of the water column in the tank is draining out,its hot water coming out), but is it *normal* for the water to be only luke warm for the first few minutes? Or, is this indicating something wrong with the lower heating element?
Before I pull things apart and try a continuity test on the elements, wanted to get your opinion. This is mt first electric water heater, so my sense of what is/should be 'normal' is pretty minimal (for my gas fired water heaters, the water that came out during a flush was hot from the get-go). If the (lower) element comes up faulty, warranty fix,but...before I pull that trigger.
Thanks in advance...
