jamco70
1. Started getting warm water instead of hot water from 7 year old Rheem electric water heater set to 120 degrees.
2. After research, I replaced both elements.
3. When I turned the power back on, the water heater immediately threw a "Lower thermistor failure" code.
4. Rheem no longer makes this particular thermistor and I did not want to wait 2 weeks to get it from Home Depot by mail.
5. Replaced water heater with brand new Rheem water heater. Set one thermostat to 120 and the other to 125, according to manual.
6. Experiencing same problem....have to turn temperature control all the way on Hot to get warm water in shower, kitchen faucet, and master bath faucet. Haven't put a thermometer on the "hot" water but there's no way it's coming out at 120 degrees. It's like 100 degrees.
7. Talked to plumber, suggested it is a bad mixing valve in the kitchen sink faucet????
I have never heard of such a thing. Before I spent hundreds of dollars more on a plumber or time to throw parts at the kitchen faucet mixing valve, can anyone weigh in on this? Is this a real thing, could it be this or something else? Have been dealing with this for going on 2 weeks now.
Side note: we are remodeling the master bath and replaced the cartridge in the Moen shower body but the shower tile isn't done yet so we haven't been using that shower. Could a wrong or improperly installed cartridge be the culprit?
