Hi there,
The main water line coming into my home is equipped with a gate valve. I had to replace my hose facet this summer and noticed that the valve would not completely close which made the repair a little more difficult (and wet). I'm looking to replace the valve with a ball type but had a few questions.
1. Is there a specific type of ball valve I would need? One made for main water lines?
2. Can I use compression fittings or does it need to be soldered?
3. Do I need to remove the old valve or can I install the new valve further up the pipe?
4. The portion of pipe below the valve has a blueish/greenish film on it. Is this an issue, should I replace this section of pipe while I'm at it?
