Need help with what water pressure valve to get on main water line.
Jfunchio
Jan 16, 2022
6
United states
Hello,
We recently found a link in the water pressure valve on our main water line and need to replace it. From doing a little research I was looking at the Wilkins NR3XL and Wilkins Model 500XL and I believe this is dependent on our upstream water pressure. The current valve we have is the Wilkins Model BR4. Pressure Range: 15-150psi, Max Temp: 180deg, Max Inlet Pressure 400psi. If someone has a recommendation that would be super helpful.
It looks like a pretty simple install, but I am attaching some images as well, so any help with what each lever and valve does would be helpful. I see two shutoff levers and what I believe is a faucet to check water pressure. Let me know if this is incorrect.
    1.6 MB
    1.5 MB
    1.6 MB
The 2 lever valves stop the water the other round handled valve will drain the water from the pipe and pressure regulating valve your going to change there is a direction of flow arrow on the valve
