Hi all. Any help would be MUCH MUCH appreciated.
Here's the situation...
I have a well system that only had a max of 28 psi pressure. Well pressure tank only had 28 psi IN the tank. After reinflating the pressure tank the pressure soon dropped down again in a matter of hours. I've replaced the pressure tank which now has 40 psi in it(and holds). I've also installed a check valve as the water seemed to be flowing back into our well. However I now only have a max of 24 psi on the pressure gauge even when the well pump kicks in pressure doesn't seem to go any higher. Any ideas?
