jakester
I am upgrading from a single sink (30" vanity) to a double sink (60" vanity) my question is how to run the plumbing the correct way? In the attached pictures you can see where the only sink was, the second sink will be to the right of that one. I need to keep the plumbing in the wall because I won't be able to run inside or underneath the vanity. Also what size pipes should I used and what size pipe should be coming out of the wall?
